Track S2000 burned down and rebuild!
if you look up "s2000 j's oil filter stay" on google you see basically what i have and never had an issue after 5 years of hard track abuse. i thought $100plus was ridiculous so i basically made one for next to free. just a small piece of scrap steel i had around the garage (16ga iirc) cut a small strip, folded the end over and drilled a hole in it. took all of 15 minutes start to finish to make it. one end bolts onto the upper motor mount bolt hole and gets pinched between the mount and bolt. then there is a tab nearly touching the oil filter, worm clamp it, boom done.
BUT, i've been using this for the past 7 years....
https://h-tune.co.uk/tegiwa-oil-filt...iABEgIszvD_BwE
altiain
Apr 23, 2012 10:52 AM
