Tracking s2000
Old Jan 9, 2011 | 07:59 AM
unbreak_s2k07's Avatar
Default Tracking s2000
When I go to the track which is at Streets Of Willow, What should i do to my ap2?
should i buy better grippier tires and maybe some coilovers? or should I stick with my Hankook HR-II and stay stock and learn how to handle my car with crappy tires?
Old Jan 9, 2011 | 08:16 AM
bellwilliam's Avatar
only one:
1. get a better brake pads. minimum XP8, or similar ones from other brand.
don't bother with changing tires nor suspension.
Old Jan 9, 2011 | 08:41 AM
what about tire pressure?
I have 255/40/17 in the rear on oem wheels should i stick to the oem specs for tire pressure or should i go 32 psi in the front and 40 in the rears?
Old Jan 9, 2011 | 09:07 AM
turbo8765's Avatar
Why would you go so much higher in the rear?
Old Jan 9, 2011 | 10:20 AM
PedalFaster's Avatar
You know, this forum has a FAQ: https://www.s2ki.com/forums/index.php?showtopic=520674
Originally Posted by tinkfist,Aug 28 2007, 12:12 PM
Q What mods do I need for my first track day?
A You need a helmet (probably), a car in good shape and with plenty of brake pad life remaining and that is all. Please don't ask this question. If you want to ask "What do I need for my second track day" then please by all means do so but not until you have completed at least one HPDE or lapping day first. Just check your brakes and make sure you've fairly new pads and make sure you've got a full engine worth of oil. If anything bring an extra quart. You don't need wheels, suspension or any other modification for your first track day. Come back and see us when you are done. Again, in case you missed it, TAKE YOUR CAR TO THE TRACK COMPLETELY STOCK THE FIRST TIME. 'nuf said.
Feel free to up your tire pressures a bit, but please don't run your rears 8 pounds higher than your fronts unless you plan on driving the track backwards.
Old Jan 9, 2011 | 12:11 PM
traction
Old Jan 9, 2011 | 01:13 PM
Harpoon's Avatar
32 cold all around, better fluid and better pads.
Old Jan 9, 2011 | 01:31 PM
Whitefire818's Avatar
Originally Posted by unbreak_s2k07,Jan 9 2011, 01:11 PM
traction
That doesn't make sense.
When your tires warm up the air inside will expand. If the pressure is too high to tire won't flex at all and will slide easier. Not to mention you will wear the inside of the tire faster instead of having a more even wear with lower pressure.
Correct me if I'm wrong guys but that's what makes sense to me.
Old Jan 9, 2011 | 01:39 PM
traction
40 cold is way too high for optimal traction.
You're overthinking this. It's your first visit to the track -- just show up, drive, and have fun.
Old Jan 9, 2011 | 02:07 PM
turbo8765's Avatar
Exactly.
I run 32 cold F & R. I seem to gain about 10psi in a 20 min session.
