Trailer hitch?
Old May 21, 2007 | 09:14 AM
  #141
gomarlins3's Avatar
Yes, I have one.
Old May 21, 2007 | 09:30 AM
  #142
tdrag97's Avatar
price? and condition?
Old May 21, 2007 | 10:16 AM
  #143
gomarlins3's Avatar
Condition= good. Price= $10,000..... it's not for sale.
Old May 21, 2007 | 10:29 AM
  #144
Orthonormal's Avatar
Originally Posted by hecash,May 15 2007, 07:29 AM
You can then easily run the wires out through the rubber vent on the driver's side of the trunk and fasten the wires with a zip tie or grommet.
I routed the trailer wire out through the rubber grommet that the license plate light wiring goes through. It's right above where I installed the controller box, which is against the rear metal wall of the toolbox well, in the gap between the fiber trunk liner and the metal wall. The plug wire is just long enough for the plug to be pulled out over the top of the license plate, and it tucks behind that panel when not in use.
I thought that the vent you're talking about had a flapper that closed. Does the wire hold the flapper open?
Old May 21, 2007 | 10:33 AM
  #145
tinkfist's Avatar
The flapper is an air vent for the trunk. The flapper is simply a flap of rubber. This is how my harness is run as well.
Old May 21, 2007 | 10:35 AM
  #146
tdrag97's Avatar
Old May 21, 2007 | 11:05 AM
  #147
Right -- the flapper is meant as a 1-way valve to let air out of the trunk but not in (carbon monoxide bad). I wouldn't want to prop it open with a wire, but I'm picky.
Old May 21, 2007 | 11:12 AM
  #148
tinkfist's Avatar
I've been running the setup for ~6k top up miles and I am still alive
Old May 21, 2007 | 11:15 AM
  #149
gomarlins3's Avatar
Ditto.
Old May 30, 2007 | 10:35 PM
  #150
mikegarrison's Avatar
[QUOTE=Orthonormal,May 15 2007, 08:19 AM] Huh, maybe they changed their minds after I talked to them the weekend after qualifying.
