understear
Old Oct 25, 2009 | 08:33 AM
vassosva's Avatar
Default understear
Hi, I have the Ohlins DFV with Cusco stabilizers and tyres 225/45/17 fr and 255/40/17 Re. The Car is 99 JDM
I use the manual guide for adjusting the suspension except in front where I adjust the height 2mm more because I was hitting the fenders.
All around the ride height is 345mm and from the ground 110mm fr and 115mm back
What kind of alignment would you suggest?
Right now I have:
Fr.
Clicks 8 (25 is softest)
Caster +5.70mm
Camper -1.45
Toe 0.00
Re
Clicks 10 (25 is softest)
Camper -2.25
Toe +1.70
And the car is very much understear and you can’t drive it at any circumstances to the limit.
ANY ideas or suggestions to stop the understear and for the best alignment.
Thanks
Vass
Old Oct 25, 2009 | 09:18 AM
macr88's Avatar
Try more front camber, at least -2 and more if you can get it.
Old Oct 25, 2009 | 11:28 AM
PedalFaster's Avatar
That's a lot of rear toe in -- why not just dial some of it out?
Old Oct 25, 2009 | 04:04 PM
Billj747's Avatar
+1.7 is degrees or mm?
So the car is understeering = the car dosnt want to turn very well or change direction? Is it unresponsive at turn-in as well?
What are the spring rates F&R?
Does the back end ever slide out?
Old Oct 26, 2009 | 02:07 AM
vassosva's Avatar
the +1.7 is mm the spring rades are 10k front and 8k rear
Old Oct 26, 2009 | 03:25 AM
samsam5886's Avatar
The front is too stiff.
Old Oct 26, 2009 | 06:10 AM
vassosva's Avatar
And I find it too soft!!!!
walshman
Feb 22, 2010 06:13 AM
Nu4mulaRedd
Nov 2, 2009 04:02 PM
sillyboybmxer
Apr 22, 2009 05:17 AM
nichigo
Jun 24, 2007 08:49 AM
ras2k
Apr 22, 2003 07:02 AM
