Using the spare with Victoracers
Tried the search but didn't find anything. I was thinking of removing the spare to save a little weight. Currently, I have Victoracers mounted on stock wheels that I drive to the local autox. I was wondering if I got a flat front or rear, would using the spare cause any damage do to slight size differences. If it will, I will leave the spare at home. If it doesn't, I will take it with me.
TIA
TIA
Stock front and rear are 0.2 inches different in diameter. If your victoracers are comparable, you'll be fine. If the difference is bigger - well, so far as I can tell nobody has any idea what the stock differential can take without issue.
I'm not sure if you're wanting to NOT have the spare in the car (saves weight and lowers the CG a little bit, worth doing) or if you're concerned with using the spare in conjunction with the Kumhos. If the latter, use the same strategy as with the stock tires - use the spare in front and the front tire to replace the flat rear. The smaller diameter of the spare could do damage to the diff.
I agree with Jeff, use the spare in the same manner as you would use it with the OEM tires.
Here's a variation of this scenario. A few days ago I noticed a nearly flat left rear tire as I was leaving my garage. So, in order to avoid all that tire switching when using the spare, I simply temporarily installed one of the rear wheels that I use for autocrossing (Kumho V700). I was interested to note that when accelerating the car pulled left, and when braking the car pulled to the right. I would have excpected the opposite - I guess I really don't understand traction and tire dynamics enough. Can anyone explain this phenomenon?
mwy23
Mar 2, 2003 11:17 PM
