Valve Adjustment
Old May 14, 2008 | 07:30 PM
goldsS2000's Avatar
Default Valve Adjustment
So, I talked to a friend of mine and see said Im developing a problem an s2k owner from ATL had. When I drive the valves chatter and occasionally the car will bog down too far when it comes down to an idle. WTF do I do?!?!?!
Old May 14, 2008 | 07:47 PM
mikegarrison's Avatar
I doubt if it is the valves. S2000s are known to have "heat bog" issues. But feel free to pull the valve cover and check the clearances. There's a good writeup on this in Under The Hood.
Old May 14, 2008 | 09:27 PM
s2kattack's Avatar
keep in mind that the write-up has the firing order wrong.
it is 1-3-4-2.
it also says to turn the crank pulley counterclockwise.
you should turn it clockwise to keep the correct firing order. our engines turn clockwise.
some people might want to turn counter-clockwise to make it easier to turn(no compression), but if you do this, you will have to go backwards(1-2-4-3)
or you can take out your sparkplugs and go clockwise. this will make it easier to turn.
Old May 17, 2008 | 12:00 AM
goldsS2000's Avatar
well, i talked to this guy and he ended up needing new valves, guides, and machine work out the ass, bout $2000 worth <8-o
nibble
Sep 3, 2023 11:44 AM
Rockin S2K
May 4, 2018 05:15 AM
rikhemi
South Florida
Oct 21, 2014 07:04 PM
SpitfireS
Feb 1, 2013 02:34 PM
codyh
Jul 23, 2012 03:41 AM
