Very Interesting Camber Joint/Roll Center Adjuster
Old Sep 28, 2011 | 06:58 AM
//steve\\'s Avatar
Default Very Interesting Camber Joint/Roll Center Adjuster
So someone posted a link to this Rayra Factory page and I was looking through their s2000 parts and came across this.
It's labelled as a roll center adjuster/camber joint and it look me a minute to figure out how it worked but now it's pretty obvious. Your thoughts? Basically it would let you retain the factory ball joints and probably be the most simple install possible as you don't even need to remove the ball joint from the control arm. Just undo the two bolts and reinstall with new bolts.
Now the question is does that look sturdy or sketchy? If it was a solid piece I feel like there is a lot of potential for someone to duplicate this and make an even better alternative to what we already have.
The most obvious thing I question is what negative affect is there on having that entire ball joint piece slightly angled as it would be with these?
Old Sep 28, 2011 | 07:10 AM
IntegraR0064's Avatar
So basically it keeps on bolt in the same place and moves the other one out a little bit, therefore angling the joint and moving it out slightly?
I was actually thinking that when I put in my J's joint...why not just offset the factory one?
If I'm looking at that right it'll move the ball joint down quite a bit too - wonder what that will do?
Old Sep 28, 2011 | 07:53 AM
//steve\\'s Avatar
^Exactly. It just angles the ball joint a little which offsets it from the rest of the hub. Moving it down makes this not only a camber joint but also a roll center adjuster. Pretty much win win if you ask me although I'd feel more comfortable if it was a completely solid piece
Old Sep 28, 2011 | 08:14 AM
Cool.
Any idea on price? It's JDM so it probably costs more than a new ball joint.
Old Sep 28, 2011 | 08:16 AM
//steve\\'s Avatar
It honestly looks like an extremely easy part to duplicate. Maybe the design could be slightly improved?
Old Sep 28, 2011 | 08:21 AM
I was thinking the same thing. I'll probably do that if my J's joints ever need replacing.
Old Oct 4, 2011 | 10:45 AM
//steve\\'s Avatar
bump....I'm curious to see more people put forth some input on these. Speaking of them, I have a friend I need to show these to to see if he can possibly make me some....hmmm
Old Oct 4, 2011 | 12:31 PM
GEARHEAD's Avatar
You can offset the factory joint with no additional hardware/spacers. I used an annular cutter to machine offset holes in my factory joints and then filled the original holes with a removable insert. I've been racing on them for several years. I run -3.0 to -4.0 front camber depending on tires and setup.
This design looks like a simple bolt-on solution, although it will change your roll center height which isn't always a good thing.
Old Oct 4, 2011 | 01:16 PM
//steve\\'s Avatar
^Any more details on what you did? I'm having a hard time visualizing it.
My car is low enough it would benefit from that roll center correction....I think
bobby.is.rad
Aug 23, 2014 06:35 PM
//steve\\
Apr 27, 2012 10:42 AM
airintake0_0
Feb 21, 2012 01:46 PM
mic_crispy
Nov 3, 2005 07:53 AM
jonam
May 27, 2005 03:38 PM
