View Poll Results: Which setup is best for the track?
Voters: 17. You may not vote on this poll
Wheel setup on track
I'm really bored at work today
, so I am starting a new poll to try and create some discussion. Thhis is kind of a follow-on to one of my other topics. Is a wider track (by using lower offsets) beneficial? All other factors being equal with the same driver, would an experienced driver using 17 x 9 with +35 offset be faster around most tracks than when using 60 offset? Is a 17 x 8 +50 nonstaggered setup better than a 17 x 9 +60 setup?
I'm not an expert but from what I understand the widest wheel that fits under your fenders is going to be the best one.
Something poking out is obviously going to hurt you by causing a drag penalty at speeds on track.
That being said I believe my vote is obvious.
It is pretty dead here. There are too many variables to determine "the best" but I prefer 17x9 +55 to 60 as it gives you good fender clearance for up to 255 tires, but not so extreme as to to mess with steering geometry (personal preference).
Well, I see what you are saying, but what I guess I am asking, is running a 17 x 9 +35 with wide fenders and overfenders going to be better than the higher offsets that fit stock fenders? I am not concerned about the cost of bodywork, but moreso whether this setup would be better.
As far as wider is better, I would think that to a point...255s are a little stretched on a 10" but one member I remember said the feeling of the 255 on a 10 was better than the 255 on a 9.5 or 9" wheel to him. But wouldn't there be a point where adding too much width to tires need to be countered with extra power because of the rolling resistance and or/weight? Like 275s all around for example.
i know in theory it should give more grip, and change your roll center (from what i've read). and would also apply more force to your shocks/springs, and thus might require a stiffer setup to compensate. beyond that, dunno.
in events where there are no budget constraints, or even any design contraints, cars still never have wheels pushed ridiculously outward, so i assume at some point advatages outweight disadvantages. wish i knew what the tradeoffs are.
But a lot of the major "racecars" seem to be running widebodied vehicles, so it seems like there has to be an advantage:
All the major Japanese tuners have a widebody: ASM, Js, Amuse, Top Fuel, Tracy Sports.
Is the only "disadvantage" that you add points if you are trying to stay in stock class or like the TTC for time trials?
wowwitsgau
Jan 24, 2014 09:46 AM
sspicollo8
Jan 1, 2008 11:22 PM
