Wing+top down
Old Jan 13, 2009 | 03:05 PM
DCIdevil's Avatar
Default Wing+top down
Is having a wing on my car at track days with the top down counterproductive?
Does it jack up and scramble the air flow?
thanks
Old Jan 13, 2009 | 05:31 PM
krnmike's Avatar
your hair will create a lift and vacuum in the cabin.
Old Jan 13, 2009 | 07:14 PM
zbrewha863's Avatar
Even if the airflow was scrambled, the wing would still be giving you downforce so it would still be better than no wing.
Obviously top up would be better, because you would most likely be getting air with more of a clean stream, but the air is still very scrambled coming off of the softtop.
Old Jan 13, 2009 | 07:21 PM
patinum's Avatar
Duh, he'll be wearing a helmet
Old Jan 13, 2009 | 08:44 PM
DCIdevil's Avatar
I figured i'd ask. I didn't know if it may create something that harms lap times as oppose to helping them.
persay too much downforce or maybe even lift
Old Jan 13, 2009 | 10:29 PM
krnmike's Avatar
with the consistancy of a human being, i'm quite sure little mistakes here and there will be the bigger reason for changes in laptimes.
Old Jan 13, 2009 | 11:01 PM
VitaRenovatio's Avatar
Does human error compensate for the drag differences of having top up vs top down, though?
Old Jan 13, 2009 | 11:23 PM
krazik's Avatar
Administrator
absolutely it affects lap times. The car is MUCH slower w/ the top down.
wing or not doesn't matter.
Old Jan 13, 2009 | 11:41 PM
All this time, I've been running top down. Not like my laptimes really matter ... yet.
I heard that if you run at high speeds with top up, you may damage your frame because of the parachute effect. Has anyone experienced anything like this?
Old Jan 14, 2009 | 12:04 AM
krnmike's Avatar
I thought there was a new rule that requires convertible tops to have tops up
