WOT A/F ratio
Administrator
ohh narrow band is useless, it just tells you if you're too lean or too rich, not much inbetween. get a wide band in the there before you make changes. Just go to your local dyno shop and have them give you your a/f #'s from a couple runs.
-Ry
-Ry
Test Pipe will make your car run lean? Mine is rich also...stock when I tested it.
I have a test pipe on the car now, but didn't think it was significant enough mod to go to the dyno again. It certainly smells more rich.
I got my readings from the Dyno, through that prod they stick up the exhaust of the car.
Will getting a less rich setting gain power on the car?
