WOT A/F ratio
Old 08-06-2006, 11:12 AM
gerryk's Avatar
Default WOT A/F ratio
How abnormal is an A/F ratio of 12 on WOT in VTEC. My car has IHE--otherwise stock engine.
Old 08-06-2006, 11:17 AM
CosmosMpower's Avatar
12:1 sounds pretty safe for a N/A engine, maybe even a tad rich. I think you can have up to 13:1 for a N/A engine and 11-12:1 for forced induction.
Old 08-07-2006, 01:51 PM
Harpoon's Avatar
That's low.
Old 08-07-2006, 02:14 PM
gerryk's Avatar
Any advice as to how to address this issue?
Old 08-07-2006, 04:04 PM
Administrator
krazik's Avatar
ecu or vafc
Old 08-07-2006, 04:05 PM
Administrator
krazik's Avatar
also where did you read the a/f from and what type of sensor?
Old 08-07-2006, 04:40 PM
gerryk's Avatar
I think it was a narrow band o2 sensor and it was on the header. How would a vafc fix this. And wouldnt that bump me out of H1 into HU
Old 08-07-2006, 05:31 PM
Administrator
krazik's Avatar
ohh narrow band is useless, it just tells you if you're too lean or too rich, not much inbetween. get a wide band in the there before you make changes. Just go to your local dyno shop and have them give you your a/f #'s from a couple runs.
-Ry
Old 08-07-2006, 06:43 PM
Harpoon's Avatar
If you're still low, throw on a test pipe. That'll put you leaner for sure.
Old 08-08-2006, 01:06 AM
7gk20a's Avatar
Test Pipe will make your car run lean? Mine is rich also...stock when I tested it.
I have a test pipe on the car now, but didn't think it was significant enough mod to go to the dyno again. It certainly smells more rich.
I got my readings from the Dyno, through that prod they stick up the exhaust of the car.
Will getting a less rich setting gain power on the car?
Quick Reply: WOT A/F ratio
