ap1 modified vs 05' m3
Originally Posted by Whitedeon8,Apr 20 2006, 09:20 AM
Correct me if I'm wrong, but shouldn't an N/A S with gears be even if not pull a bit on a stock M3?
i believe the stock ///M runs like 4.9. Also remember that w/smg, he has launch control - basically you can mash the gas (it pegs at 2900) and hold the gear in 1st. When you engage the gear, the computer launches w/minimal wheel spin. So basically you have to nail your launch or he'll take you off the line and by the time you make up that ground, you'll be at 80 (///M3s powerband 3rd gear) and it could be tough.
But since you're juiced w/a bunch of goodies, I think you'll have the edge - as long as your tires hookup immediately when you launch.
Originally Posted by slimjim8201,Apr 20 2006, 11:39 AM
Gears alone would make this a very close race. A supercharger at 7 psi and gears? I cannot see you losing. In fact, you should pull easily.
With a juiced setup, the S will gain some much needed Torque and higher top end so it should pretty much win from the start. Again, this is assuming the S2k driver knows how to launch and can hookup the tires when the clutch drops.
Anyways....
Hout bang and wayne!!
Originally Posted by BARs2000,Apr 21 2006, 11:03 AM
Anyways....
coming from a guy that likes to drop gears on the highway from 5th to 2nd.Haha..
E46fan
Originally Posted by derryck,Apr 20 2006, 05:35 PM
Consider yourself corrected then...I will spank the daylights out of any S2000 with just gears although my car is a 6MT. A geared S2000 might hang through most of 2nd but it should be over after that vs. a stock M3. SMG is a tad slower to 60mph than the 6MT but still should have no problem with a non FI'd S2000. Look at the trap speeds of the S and the M3...not really close. My car is stock except for software and I shed some weight and expect to hit 110mph my next outting in Gainesville...an S2000 needs FI to approach 110mph in the quarter.
110 mph is very impressive. Also, when you mention software and weight reduction, can you be more specific? That is a pretty broad statement, as my software gave me 10-15 whp in the midrange from 4000- 7500 rpm. Software can do a lot my friend. I was referring to a bone stock M3.
