10 years, still on original a/c compressor charge
Old Feb 25, 2012 | 03:17 PM
Mondo131's Avatar
Dont really know about manufacturers recommendations for the s2k, but i would be fine putting off the shelf (higher quality the better obviously) refrigerant lubricant in. Would use the same brand as the r134a you purchase.
Old Feb 25, 2012 | 03:44 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
2003 with 115k on original charge.
Old Feb 25, 2012 | 04:31 PM
2003AP1's Avatar
I wonder, is it ok to mix and match all PAG oils? If you have a leak no matter how small you really shouldnt really keep refilling it. R 134a is still a green house gas and isnt good to let into the enviornment. This is what I read, and I am no enviormentalist, lol but do the right thing.
Old Feb 25, 2012 | 05:08 PM
zeroptzero's Avatar
That's what I was wondering because every refrigerant manufacturer can use a different oil, just wondering if it is okay to mix them and work okay with our compressors/seals/etc...
Old Feb 26, 2012 | 06:27 AM
jelliotlevy's Avatar
Originally Posted by Mondo131
Originally Posted by JFUSION' timestamp='1330198642' post='21450780
[quote name='omairtheman1' timestamp='1330197715' post='21450756']
^ this guy knows what he is talking about. I recharge systems all the time and usually a leak is when you have an issue. Usually leaks are so small that it's worth putting in a can of R134a every year or a couple years. Anything more than that you should put a dye in there and UV test it for leaks.
I often wondered if we could use those over-the-counter refrigerant canisters on our cars if we should ever need a top up ?.
My experience shows that any AC system for vehicles uses R134a.
The old R12, environmentally damaging coolant(Freon), is for older vehicles.
[/quote]
Exactly my concern. In the middle 1990's, automotive air conditioners all switched over to the R134a. This is a much smaller molecule than the old R12, and hence more prone to tiny leaks - no vacuum is so perfect that no molecules ever leak out over time. My original question is whether ten years is a normal time for refrigerant to last in the system without recharge.
Old Feb 26, 2012 | 07:15 AM
GSteg's Avatar
10 years can definitely be normal. I have another car that's already approaching 15 years and it's still blowing cold as hell with the original refrigerant.
I find that most leaks occur at the seals. If you don't use your AC enough, the seals won't be lubricated so they eventually dry out. I run my AC at least once every few weeks, even during the winter (defrost anyhow).
Old Feb 26, 2012 | 07:35 AM
2003AP1's Avatar
Originally Posted by jelliotlevy
Originally Posted by Mondo131' timestamp='1330202767' post='21450910
[quote name='JFUSION' timestamp='1330198642' post='21450780']
[/quote]
[/quote]
I can see how this is plausible. But I think your talking about EXTREMELY small amounts. Like it will take 100+ years for this to happen. By that time you would have gotten a leak from a failing seal. I believe it is pretty air tight seal, think about the pressures it needs to be able to sustain.
Old Feb 26, 2012 | 08:51 AM
ChrisHS2000's Avatar
Honda A/C systems are rock solid. Not as powerful as Ford/GM, but they seem to last forever. Never touched my Accord's after 10 years and 200k miles.
Old Feb 26, 2012 | 09:28 AM
rob-2's Avatar
04 original at 102K. I did check the PSI levels and it was off 1psi on both sides.
i_luv_s2k
Aug 5, 2012 02:00 PM
RotaxMax
Jul 7, 2009 10:11 AM
pdexta
Sep 3, 2008 08:44 PM
boltonblue
Dec 7, 2007 06:33 PM
