intermittent ac problem
Old Aug 5, 2012 | 10:59 AM
i_luv_s2k's Avatar
Default intermittent ac problem
sup s2ki fam,
Just recently from time to time, my ac will stop blowing cold air (switch on the whole time,original frion) for like a few minutes, then resume proper working order. Should I be worried about a frion addition,ac switch, or relay in the near future? Thanks in advance! peace
Old Aug 5, 2012 | 12:12 PM
zeroptzero's Avatar
the system does cycle on and off and you can feel the temp difference but it shouldn't be a large difference. Apparently the compressor can shut off at higher rpms and WOT use, I haven't experienced it but it makes sense to do that, in those circumstances it can take a bit of time for the compressor to work again, but it wouldn't be a few minutes, maybe 20 seconds max ?.
Old Aug 5, 2012 | 01:13 PM
franky's Avatar
If the system cycle on n off and the ac is not as cold as it use to b tat means the pressure is low n theres a leak somewhere.
Old Aug 5, 2012 | 02:00 PM
rob-2's Avatar
Truly two minutes? Than get the system checked out. If you're being dramatic and it's closer to 30-50s it's the system cycling. On very hot days 90f+ you'll be able to feel the air temp difference - completely normal.
wpg_RSX-S
Nov 9, 2015 03:57 PM
KaNgArOo
Nov 24, 2014 12:23 PM
MTNST
Apr 15, 2012 08:55 PM
Devinb
Oct 13, 2010 05:39 PM
jaundice
Jun 6, 2010 01:06 PM
