1st Gear "CLUNK"
Dunno about a clunk, but sometimes my car just refuses to go into 1st gear. As if I have somewhere else to shift to after slowing down 5 or so MPH. Two or three tries later it goes in, but is real stiff doing so. It feels/sounds like some sort of mechanical resistance. It can do this hot or cold.
You are hearing this "clunk" because the clutch is dragging on the pressure plate. If the clutch pedal free play is adjusted per Honda's spec's, then this is likely to happen. To avoid this, adjust your clutch pedal to get more travel on the pressure plate, which will also get rid of the dragging clutch and the "clunk". In other words, lengthen the linkage from the pedal to the master cylinder, it's adjustable. This will also move the clutch engagement point away from the floor. Mine now engages several inches from the floor, instead of right on the floor.
I did this to mine in order to get rid of an ocassional second gear grind and this was successful. It also fixed the "clunk" going into first at a stop.
This could also be caused by a clutch disk that is binding from lack of lubrication. I believe that there is a TSB about this lubrication issue. If there isn't sufficient grease on the collar that the throughout bearing ass'y slides on, this will bind and the clutch will drag.
You may also find it beneficial to change the fluid in the clutch hydraulic system.
