2016 winter
Old Nov 21, 2016 | 07:56 AM
S2kcarl's Avatar
Default 2016 winter
Is there anyone out there that can help me out or give me some tips on storing my car? currently have it in a climate control unit. I went into the store tips thread but was mainly for outside storage. Any tips for a climate control unit on things I should do to keep it as good as possible??
Old Nov 21, 2016 | 07:58 AM
RedCelica's Avatar
Here's a good thread on the topic.
https://www.s2ki.com/forums/new-york...e-tips-989245/
Feel free to use the forum search function...will yield a lot of results for you! Welcome to s2ki
Old Nov 21, 2016 | 08:00 AM
S2kcarl's Avatar
That's the thread I've been looking at but don't seem to find anything for an indoor storage
And thanks
Old Nov 21, 2016 | 10:24 AM
Conedodger's Avatar
  • Detail the car in and out.
  • Add Stabil to the gas, fill it and run the car for 5-10 minutes with the AC on. (The drive home from the gas station should do it.)
  • Change the oil and filter.
  • Pump the tires to 40 psi.
  • Connect a tender to the battery.
  • Unlatch the top, but leave it up.
  • Put a few mothballs* in 3 open containers. Place one in the trunk, one in the interior, and one in the air box to keep mice out. (*Pure peppermint oil on cotton balls works and smells better but needs to be refreshed monthly.)
  • Cover and walk away until spring.
Old Nov 21, 2016 | 10:39 AM
S2kcarl's Avatar
Alright so I've done everything but the moth balls and leaving the top unlatched so I'll get that done
Old Nov 23, 2016 | 04:11 AM
dave_'s Avatar
What is your reasoning for unlatching the top?
Old Nov 23, 2016 | 05:44 AM
Conedodger's Avatar
Probably not necessary, but it takes some tension out of the fabric and frame and allows things to relax.
Old Nov 27, 2016 | 09:34 AM
rpg51's Avatar
Another tip - maybe the most important - is to put the car in storage in late fall after rodents have settled in their bedding areas for the winter.
Old Nov 28, 2016 | 05:38 AM
NH_s2k_Guy's Avatar
A couple of things I do that you could add to the list if you'd like:
- Put a rag in the exhaust tips and air cleaner input to keep rodents out.
- Lay some dryer sheets on the floor and in the trunk, helps repel rodents and smell better than mothballs.
- Leave the windows open a little bit to allow for circulation and reduce the chance of condensation.
- Put some paper towels under the windshield wipers to keep the rubber from sticking to the windshield.
- Don't leave the climate control in recirculate mode, also helps to allow air circulation.
- Leave the car in reverse gear.
Old Nov 28, 2016 | 07:24 AM
colnagotifosi's Avatar
I added to the winter thread posted above to park on four boards (I'm using old deck step treads) and even better is a rectangle of 1" foam/wallboard insulation on each board and launch the car up on those for more tire protection from sitting on the concrete or tarp. And if you think you don't have mice, you do so get traps and bait with chunky peanut butter and use the mothballs.
drshottest718
44
Dec 13, 2016 02:42 PM
needans2k2
Jan 15, 2013 09:01 AM
Mongo84
Nov 17, 2008 02:43 PM
Merilee
Mar 12, 2008 07:40 AM
Slo Ryde
Oct 2, 2003 07:44 PM
