215 Whp Stock 04
Old Mar 13, 2006 | 05:56 PM
sodaking663rd's Avatar
those are great numbers but to clarify stock means stock meaning no performance mods whatsoever.
Old Mar 13, 2006 | 06:02 PM
vbb's Avatar
vbb
That's maybe 4whp higher than what I'd expect, but still within "spec". And yes, that K&N drop in filter definitely can be good for 2-3whp gain. I put down 205.4whp on a dyno dynamics, which reads a bit lower than a dynojet. In a loose estimate, I would have put down around 210-211whp with just an AUT cooling plate and K&N drop in on an otherwise stock AP2.
Good numbers!
Old Mar 13, 2006 | 06:05 PM
2QYK4U's Avatar
Nice numbers! Real close to mine--I made 230rwhp (dynapack) stock.
Old Mar 14, 2006 | 05:41 AM
DKEN's Avatar
WoW high #'s
derek
Old Mar 14, 2006 | 05:51 AM
YellowS2kPwr's Avatar
Where do you guys dyno really? No stock s2000 should be making more than 205 whp @ an accurate dyno.
Old Mar 14, 2006 | 06:12 AM
Elistan's Avatar
Different kinda of dyno machines yield different numbers. Dynapack dynos require the removal of the rear wheels - less rotational intertia translates into higher numbers.
PilotKD's Avatar
Dynapacks dyno higher than Dynojets. It's normal. From reading lowest to highest it's: Mustang Dyno<Dynojet<Dynapack.
Old Mar 14, 2006 | 06:36 AM
Wisconsin S2k's Avatar
Originally Posted by DKEN,Mar 14 2006, 08:41 AM
WoW high #'s
derek
dynapacks always read higher. that's because you dyno without the wheels on, so it shows more hp. since the car doesn't have to deal with the rotating mass of the wheels, it makes it look like you're making more power.
dynapacks are good for tuning though.
Old Mar 14, 2006 | 06:54 AM
2QYK4U's Avatar
Originally Posted by DKEN,Mar 14 2006, 07:41 AM
WoW high #'s
derek
At most the dynapack will read 10% higher than a dynojet. I made 235rwhp with the Invidia exhaust, so on a dynojet it should be no less than 211.5rwhp.
Old Mar 14, 2006 | 10:33 AM
124Spider's Avatar
Nonsense.
My absolutely stock '04 (well, it does have an aftermarket head unit, and DOT4 brake fluid) did 219 uncorrected, 210 corrected, on a dynojet dyno. I think that's fairly standard for an AP2.
You're confusing AP2s with AP1s.
