2nd Gear grind fix problem.
Old Oct 20, 2000 | 08:46 AM
Unicron's Avatar
I just got my car back yesterday from having it serviced as recommended by the Honda 1-2 Gear Grind Bulletin.
No grinds yet...but it seems like the clutch does not grab second gear anymore.
I used to be able to chirp second like crazy...but I can't do it now...
The Honda service rep says that I have to break 2nd in a bit before it starts to tighten up...what do you think?
Old Oct 20, 2000 | 08:51 AM
Unicron's Avatar
Let me describe the situation a little better. Yesterday after I picked the car up around noon, I drove around all day to work in 2nd gear. Later on I decided to test 2nd gear out. I revved 1st to about 8500 rpm and did the usual to try to chirp the tires. Instead, it felt like the clutch wasn't grabbing 2nd and no chirp.
Old Oct 20, 2000 | 08:57 AM
Tox's Avatar
Tox
They probably readjusted your clutch when they put the car back together. IMO you should give yourself a few days to get used to it and then try again.
Old Oct 20, 2000 | 11:22 AM
Silver S2K's Avatar
"I just got my car back yesterday..."
YIKES! Break the new gears in first! You didn't go around ripping second when the car had 0-10 miles on it did you? You're new gears need, in my opinion, at least a tank of gas worth of miles to break in w/gentle driving.
Old Oct 20, 2000 | 11:29 AM
Unicron's Avatar
The dealer put 11 miles on it for testing.
I put about 20 more before I tried out 2nd gear.
Old Oct 20, 2000 | 11:34 AM
Silver S2K's Avatar
Your call, but I put about 150-200 miles on mine before I ventured into V-Tec again. Mine feels stronger than before. Could also be the dealer screwed your clutch up.
Old Oct 20, 2000 | 02:48 PM
Unicron's Avatar
Silver S2K,
Thanks...I'll cool it for 100 miles and see what happens.
Thanks a million,
Old Oct 20, 2000 | 04:52 PM
Silver S2K's Avatar
No problem Uni. I'd save going back to the dealer for a last resort. I've found that the more miles I've put on after the fix, the better things feel. I can get the rears to scratch on quick one, two shifts anywhere above 8,100 rpm. So if things don't get better after 100-200 miles, I'd take back to the dealer; It's not the nature of the fix once broken in.
reedntrack
Jun 27, 2007 10:30 PM
gravit
Apr 30, 2007 08:08 AM
McMuffin
South Florida
Dec 27, 2006 06:24 AM
DWynne
Apr 19, 2003 07:58 PM
LyNX
Jun 11, 2002 08:54 AM
