2nd gear problems
Old Jan 19, 2005 | 07:42 AM
cetro's Avatar
Default 2nd gear problems
Hi all. I just purchased an 05 and I'm having problems with second gear. When I'm cruising to a stop the car pops into neutral. Car has about 350 miles. It gets better as I drive the car, but as soon as i turn off the car for ten minutes and start it up again it does the same thing. Any ideas?
Thanks
Old Jan 19, 2005 | 12:01 PM
StockSH's Avatar
hmm.. Does it happen when you are decelerating?
my 04's 2nd gear poped out to neutral when I was slowing down( with no gas)...
well.. my salesman told me he had another 04 customer having same problem..
anyway.... They fixed my transmission under warranty...
Old Jan 19, 2005 | 12:13 PM
gotrice02's Avatar
known issue. Do a search to find a cornucopia of information
Old Jan 19, 2005 | 12:16 PM
Cyclon36's Avatar
I'm getting that 2nd gear grind in my '04. It even does it sometime after it's been warmed up and I quickly slam it into second. It get embarrasing sometimes. Is that warranty work too? I know that seems to be a common problem, but what do they do to fix it?
Old Jan 19, 2005 | 12:17 PM
gotrice02's Avatar
The warranty should work.
Old Jan 19, 2005 | 03:06 PM
cetro's Avatar
Only under deceleration with no gas.
Did they give a new tranny or just a fix? I'm not very happy about this
Old Jan 19, 2005 | 05:06 PM
hpark's Avatar
i've never heard of this.....i'd get it looked at / fixed
now the 2nd gear grind.....that i "normal" and will never be fixed
Old Jan 19, 2005 | 05:15 PM
Intrepid175's Avatar
No offense but maybe that's the problem?
The S2000 has one of the slickest shifters on the market and there is absolutely NO reason to "slam" it into gear. I've found that my car does best when I simply prod the shifter in the direction I want it to go. If I keep a solid grip on the shift leaver and try to force things, that's when I miss shifts or experience the infamous 2nd gear grind. I used to get the 2nd gear grind fairly regularly when the car was cold. At 9600+ miles, I rarely get it, cold or otherwise, and when I do get it, I generally know it's something I got sloppy with.
Drive Safe,
Steve R.
Poe408
Oct 13, 2021 11:07 AM
edis0n
Nov 12, 2007 02:31 AM
DelrayS2K
Jul 25, 2006 07:10 PM
wischuck
Jul 20, 2006 05:09 PM
ctngedg
Jul 25, 2005 08:04 AM
