4.57 gears....how much?
Old 07-19-2006, 10:39 PM
nismo300zx's Avatar
Default 4.57 gears....how much?
how much for the gears if you do it yourself, and how much (average) If somebody else do it for you???
its that hard to do it yourself??
thx....
Old 07-20-2006, 02:42 AM
Emil St-Hilaire's Avatar
Hard to do yourself;you need a knoledgeable mechanic,and special tools(bearing puller etc..).
Figure around $1000.00 to $1200.00 everything included.(yellow box etc...)
Old 07-20-2006, 04:53 AM
stitos2k's Avatar
Honestly man, you'd have a much easier and cheaper time ordering the 4.57's and comptech diff prebuilt from Stratocaster.
Its MUCH easier installing a prebuilt diff than it is installing the gears seperately. Not to mention if your mechanic doesn't get the lash set correctly you're going to hate life.
If you bought it prebuilt, you'd need a breaker bar, allen wrenches (good ones, and fairly long for leverage), 14mm and maybe 16mm sockets, torque wrench, jack stands, good floor jack (diff is heavy, its useful for getting it into place), some liquid wrench (very useful), and a bottle LE607 or Mobile1 75w90 gear oil.
I'm probably missing a few things, but that's mainly it. You won't be able to install gears yourself if your asking how hard it is. It's NOT a novice job.
Xviper has some instructions up in the How To sticky.
Old 07-20-2006, 05:02 AM
cap1's Avatar
Old 07-20-2006, 06:08 AM
xviper's Avatar
You can do "much" of it yourself (the easy part):
https://www.s2ki.com/forums/index.php?showtopic=85687
Old 07-20-2006, 11:36 AM
carloS2000's Avatar
I'd recommend Stratocaster too. Don't try installing the 4.57 gearset in pumpkin unless you have all the tools and you've done it before. Twice. Jeff is easy to get along with, does a great job and you can order the Comptech reinforced diff w/gears prebuilt or ship him your diff, which is what I'd recommend if you have a clean low miles diff & can deal with all the issues a disassembled car presents. I got a prebuilt, kept my stock pumpkin, and personally found the diff reinstall challenging. But I'm not much of a mechanic.
Old 07-20-2006, 12:14 PM
stooken's Avatar
What's the difference without having the Comptech reinforced diff with the gears?
Does it just add more safety and reliability for the extra performance?
Old 07-20-2006, 01:05 PM
SpitfireS's Avatar
Do you see that extra cap over the OEM bearing cap?
The shiny part above the "8".
That is the Comptech reinforcement.
And the bolts are stronger too.
Old 07-20-2006, 02:00 PM
xviper's Avatar
The Comptech stuff is like "insurance". Most don't need it, but some do. I've even seen here that someone busted a diff with the CT caps and bolts. Go figure.
Old 07-20-2006, 05:33 PM
stooken's Avatar
How much is the Comptech diff and 4.57 gears from Stratocaster? Do they have the 4.57r as well? Where can I get them?
I'm assuming doing this would completely go against my lease.
Quick Reply: 4.57 gears....how much?
