4.77 gear help
Old May 10, 2007 | 11:22 AM
  #21
Kenpo_S2000's Avatar
I have seen from other posts that it depends on the installer you choose. If you can get the hook up from someone you know it will be cheap. I think Mocky paid around 350.00 for his to get installed by reading his post.
Old May 10, 2007 | 11:27 AM
  #22
cap1's Avatar
for 4.77s
Old May 10, 2007 | 02:18 PM
  #23
dmarvin3's Avatar
Ok, so I'm a total newbie when it comes to installing gears. I plan on getting a set new in box..the 4.77's. Do I need to get anything else for the install... i.e. bearings, ring or pinion gear? Or from what i've read, it seems as if it is just interchangable. Don't flame me too bad for asking these questions
Old May 10, 2007 | 05:41 PM
  #24
jfw432's Avatar
I too am mostly noob on this topic but the ring and pinion is what you buy for the gear swap itself.
I've seen a varying set of install opinions and would certainly love a better explanation. Some say $160 for the install others say $450 for the install. Some buy the shim kits and others don't. Since I know you need the new shim, are people just having the mechanics provide the appropriate shim or what?
I'm all about this mod when people talk about getting the gears for $260 and getting them installed for $200 or less if you remove the diff. Then a bunch of other people start talking about expensive install kits and $300-$400 install prices and the price almost doubles to about $900-$1000 instead of less than $500.
Which is it? I know shop prices vary but not that much.
Old May 10, 2007 | 05:46 PM
  #25
ridestrt's Avatar
im dropping my car off monday to get my gears installed along with a clutch and flywheel. kia 4.77s and the HTG install kit. ill tell you guys how it goes
Old May 10, 2007 | 05:57 PM
  #26
dmarvin3's Avatar
thanks, i'd appreciate any information possible. I am searching around to see installation costs. What are the average costs on the KIA gears anyways...make sure i'm not going to be getting ripped off. Thanks again for everyones help.
Old May 11, 2007 | 05:36 AM
  #27
Cool I will be watching for the install review. Good luck with everything. Did the shop give you a breakdown quote for just the install of the gears. Enjoy the new mod.
Old May 11, 2007 | 08:20 AM
  #28
SanMarinoCpe's Avatar
The install kit should run you around $110, which include inner and outter pinion bearings, pinion nut , distance piece (crush collar)and pinion seal. The shim kit is needed to set the gears up but in some cases is not needed since the exsisting shim will be used.
Old May 11, 2007 | 08:23 AM
  #29
Is it reccommended to upgrade the diff?
Old May 11, 2007 | 08:31 AM
  #30
that is up for debate...if you can justify the cost
