5.5 Quart oil change - is this typical?
Old Jun 22, 2001 | 07:57 AM
Master Apex's Avatar
Default 5.5 Quart oil change - is this typical?
I used to just take it to dealer but for the first time, I change the oil myself (MOBIL 1) and notice that it takes up to 5.5 Quart to top up the oil.
Is this typical for those of you who change your own oil?
Old Jun 22, 2001 | 08:13 AM
cthree's Avatar
Administrator
Yes. It's in the owners manual.
Old Jun 22, 2001 | 11:55 AM
SFDukie's Avatar
Yes. I think mine took 5.3 with the last change- perhaps they weren't quite patient enough on the drain time.
Old Jun 22, 2001 | 12:25 PM
TRICKS46's Avatar
Went with the book----5.1
Old Jun 22, 2001 | 12:34 PM
jguerdat's Avatar
Mine took 5.5 qts., too. I was cautious and stopped at 4.5 qts. until I could get a good reading (clean oil is a bitch to read - used a 10x eye loop). Put the rest in and still needed another .5 qt.
We might be draining better than the typical dealer/quick oil change joint...
Old Jun 22, 2001 | 06:32 PM
S2K4ever's Avatar
Same here I changed mine Thursday at 5000 miles and it took around 5.5 quarts of Mobil1 with a PureOne filter. The oil was kind of thick where the filter was mounted. I wiped that all clean before mounting the new filter. I am glad I changed the oil at 5k and wow that filter was hard to get off. I wonder if jacking the car up in the front with the standard jack helps drain out more of the dirty oil?
Old Jun 22, 2001 | 08:53 PM
joe_s2k's Avatar
I use 5.5 US quarts every 5-6 weeks or 3k miles. I drive alot!!
Old Jun 23, 2001 | 09:08 AM
Big Al's Avatar
Takes a little more than 5.5 on mine to fill it to the line. (~5.6)
Old Jun 23, 2001 | 10:37 AM
Yellow S2000's Avatar
Just did my first oil change today.. 5.5 quarts oil..
Coldfuse
Jan 18, 2014 03:51 PM
ricky05
Dec 6, 2012 05:07 PM
asukadc
Mar 17, 2006 09:25 AM
LIL RAJA
Mar 13, 2003 03:21 PM
pellisS2k
Dec 22, 2000 04:29 PM
