oil change question..
Old Mar 17, 2006 | 06:59 AM
asukadc's Avatar
Default oil change question..
when u do an oil change manual says 5.2 qt with filter.. what does that mean? put 5.2 qt in? or put 5.2 qt in first, then let it run through the filter add lil more? dealer been doing the job but thinking gonna do it myself later on
Old Mar 17, 2006 | 07:35 AM
Wisconsin S2k's Avatar
just add 5 quarts, and you're fine. run the car a minute, then check the dipstick.
Old Mar 17, 2006 | 07:37 AM
Incubus's Avatar
That's what I do. When I got the car, it had more oil than I like in there. I don't like the oil touching the high mark.
Gloffer's Avatar
You probably shouldn't be doing your own oil changes if you're asking this kind of question. However, it means if you change your filter when you change the oil, then it will take 5.2 qts to refill your oil system.
In the old days some people would change their oil without changing the filter. Filters in general hold about a quart of oil (the small filters on S2000's probably less) so if you changed your oil without changing the filter you would only have to add 4.2 vs. 5.2 qts with a filter change.
A lot MY 00-03 S2000 owners are finding it takes 5.6 qts to refill an S2000 following an oil change that includes a new OEM oil filter. Apparently there was a typo in the owner's manual that showed 5.1 qts vs. 5.6 qts as the oil change w/filter capacity.
It's always a good idea make your final adjustment on oil level after running the engine for a few minutes following the oil change. All this and more can be found in the FAQs. https://www.s2ki.com/forums/index.php?showtopic=108435
Old Mar 17, 2006 | 07:43 AM
Cyclon36's Avatar
Yeah, 5.2 if you put on a new filter. I put 5.2 in and it comes out perfect every time.
Old Mar 17, 2006 | 07:45 AM
jah's Avatar
jah
overfill is bad because rotating parts will cause foam in the oil. oil foam will not cool or lubericate as well.
Old Mar 17, 2006 | 07:46 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Normally takes 5.5 liters,wit a filter change,in my case.!!!
Old Mar 17, 2006 | 07:53 AM
asukadc's Avatar
so on the high mark (dipstick) assuming around 5.6 or so? low mark is around what number,
Old Mar 17, 2006 | 09:25 AM
no no, hold on a second here.
there is no EXACT amount for what you're going to need to put in.
some people put 5 quarts in when they change their oil, and some put in almost 6. both get to the "full mark" when they do it, so that means they are BOTH correct.
honestly, stop worry about the .6 this or .2 that. change your oil. put in 5 quarts. run the engine for a minute. then check the level. if it's between the halfway point and full, you're fine.
FYI, the halfway point means you are about 1 quart shy of the full mark. however, DO NOT OVERFILL!
Coldfuse
Jan 18, 2014 03:51 PM
ricky05
Dec 6, 2012 05:07 PM
bgoetz
Jan 14, 2010 07:13 PM
Av8ing1
Dec 9, 2004 04:20 PM
LIL RAJA
Mar 13, 2003 03:21 PM
