About to reach the 200k mile mark.
So I just wanted your guy’s input and experiences with your high mileage s2000’s so that I can kind of gauge if what I am experiencing is somewhat normal. So I have a MY2000 with about 170k miles on it right now. I drive spirited mostly and not too aggressive by anymeans. No autox or track time. It is my daily.
So far the things I had to replace on the car were:
-Throttle body (tps issues)
-Iacv valve
-Map sensor
-Both axles (pitted cups)
-Driveshaft (too much noise and vibration)
-Radiator (Cracked)
-Motor, Tranny, Diff Mounts (cracked)
-Rack and Pinion (steering turning by itself)
-Secondary Fuel pump (stopped working so took it off)
-Almost all boots need replacing
-Car constantly having idle issues
-All door locks dont work with remote
-replaced window motors
What are your experiences?
I am constantly fixing stuff on a monthly basis
-Iacv valve
-Map sensor
-Radiator (Cracked)
06 AP2 with 194k miles and had her since 2 miles.
** major maintenance items in 12+ years of ownership...
- replaced all 4 shocks with OEM (160k).
- vtec solenoid and vtec gasket (189k)
- driver side actuator
- hex bolt leak
** minor issues in 12+ years...
- radio volume (lower) dash doesn't work.
- high beam headlights hasn't worked in 1.5yrs
considering the years and miles she's been very good. engine, tranny, differential, drive shaft, clutch are all in great working order. friend has an 07 and his clutch feels nowhere near like mine and he has way fewer miles, but he's also the 2nd owner.
'03 with 396,000 miles. Replaced:
hubs due to worn bearings
Struts
starter
alternator brushes
fuel pump (to be safe)
Rear brake caliper
New idler pulley & tensioner pulley
New clutch & throwout bearing
A few running light bulbs
PCV valve
All 4 coil packs
Cracked windshield (3 times)
Spark plugs, rotors, tires, fluids, filters, brake pads, belts, etc.
Struts
starter
alternator brushes
Rear brake caliper
PCV valve
All 4 coil packs
incredible nearly 400K!!!!
Struts
starter
alternator brushes
Rear brake caliper
PCV valve
All 4 coil packs
Struts
starter
alternator brushes
Rear brake caliper
PCV valve
All 4 coil packs
I prefer buying cars with higher mileage as I feel the car could only make there if proper maintenance has been performed. My current (3rd) s2k is an 04 with 205k miles. I bought it from the original owner with 165k miles. The original owner took extremely good care of the car, so much that when I saw it, I bought it without even driving it. It's still on the original clutch and doesn't exhibit any signs of needing a replacement. Just as rule of thumb, I've replaced spark plugs, filters, valve adjustment and windshield wipers. Going to swap out diff and trans fluid here soon. The car runs stellar
On the other hand, I bought an 08 Evo in 2016 with 21k miles. I though since the miles were low I would be trouble free. Yea...... That damn thing gave me so many issues.
RabidRat
Nov 24, 2012 08:15 PM
