ABS kicking in when stopping?
Old May 27, 2011 | 06:28 PM
notorious9i6's Avatar
Default ABS kicking in when stopping?
Hey i am about to buy a use s2k.
When braking, you can feel abs kicking in slightly as you stop. is there any way you can fix this problem? It happens sometimes only. Is it an expensive fix?
Old May 27, 2011 | 08:50 PM
TheSteel's Avatar
Um...pull out the abs module? And I've never noticed abs to ever be "slight", it's either working, or it isn't.
Old May 27, 2011 | 11:31 PM
whiteflash's Avatar
It could just need new rotors and/or pads. You might be digging in too hard to stop due to a lack of either/or.
Old May 28, 2011 | 06:14 PM
the pads and rotors looks good. where do i pull out the module? It's going to be only temporarily til i get it to a shop
Old May 29, 2011 | 01:25 AM
FluKy15's Avatar
This happened to my truck. Every time I touched the brakes the ABS would be trippin like no tomorrow. I needed a new wheel bearing and ABS sensor on it. I got lucky and that only cost me $290 to fix, I hope this helps.
Old May 29, 2011 | 03:09 AM
CKit's Avatar
Sometimes it's just a dirty sensor. They're magnets and pick up metal shavings and grime which prevent them from detecting wheel revolution. Then they think one wheel is slipping and activate ABS. If you search, there are some threads with pictures and DIY on what they are and how to clean them.
mikeabtin
Aug 3, 2009 05:47 PM
TRD_Celica
Jun 30, 2009 03:07 PM
ROTFLMAO
Oct 27, 2008 09:27 PM
Aze85
Oct 10, 2008 08:43 AM
4wheelcycle
Jul 6, 2006 09:52 AM
