ABS light is on.. Anyway to check it without the dealership?
Has your car recently been on a dyno? I'm not sure how e-tests are done where you are but when i got my emissions done, the shop ran my car on a dyno and the ABS light was on. I drove it about 1-2 miles and the light turned off. I looked online and its a pretty common "problem" if you've recently been on a dyno of some sort.
Located in Msukegon, MI.
I took apart everything no the car to do a wire tuck, dropped the rear sub frame too to clean all the suspension etc. I had to extend the ABS plug which is 21 wires or so, I check them all yesterday I did those all correctly. All ABS plug tot he sensor are plugged in as well.
energetic
Aug 5, 2010 06:30 AM
