AEM V2 CAI pros/cons
Old Jun 12, 2006 | 11:28 AM
REVZ TO9's Avatar
Banned
hey xviper, even though that umbrella thing is by Injen, will it still work with an AEM V2 CAI? Also, will it not allow as much airflow than without it?
Old Jun 12, 2006 | 11:45 AM
s2k_jay's Avatar
i got injen Cai and it works pretty good for me but aem probably about the same i think..
Old Jun 12, 2006 | 01:54 PM
xviper's Avatar
AEM and Injen are almost the same. That umbrella will likely fit without problem or at least with very little "persuasion".
The umbrella doesn't sit close enough to the filter surface to be of any obstruction. That's not a worry.
Old Jun 12, 2006 | 03:09 PM
REVZ TO9's Avatar
Banned
what can I use to block the water channel under the hood and how do I do it? Where is this located? Also, what 2 areas do I need to cut plastic and with what tool? Do I need to still spray oil on a dry flow AEM filter which came with the V2?
Old Jun 12, 2006 | 03:20 PM
moike's Avatar
Here is some more info and a water test of the umbrella mod. You can see what hole needs plugged in the middle of picture 2 (you can use tape).
Umbrella Test
Old Jun 12, 2006 | 03:25 PM
REVZ TO9's Avatar
Banned
ok thanks! I also just noticed the filter that came with the V2 says do not oil since its a dry flow. Are dry flow filters the only filters we can use with V2? Lastly, how does a shield/heat shield connect to the filter?
Old Jun 12, 2006 | 03:40 PM
LiQUiD iCE's Avatar
Tape or anything else that will prevent water flow ... Be creative.
The instructions included with the Intake should tell you where to cut. A dremel to cut out large areas, and then a razor blade or a sharp pocket knife to get smaller areas worked well for me.
I didn't spray anything on the filter the first time I put it on. Afterwards you can buy a cleaning kit from AEM that will take care of everything...
leoxle
Dec 27, 2012 11:22 AM
jthiles2k
May 21, 2011 04:41 PM
JC_S2000
Sep 6, 2006 07:08 AM
dat s2k
Sep 7, 2005 05:42 PM
