I was intending to leave my 2000 S2000 100% stock, but after seeing the Mingster Aeroscreen in person I ordered one immediately. It makes a big difference and really helped on my trip around the Western States last May. The turbulence is reduced enough that I was able to use the air conditioner with the top down at speed in 110 degree weather and remain comfortable. That wouldn't have worked without it. Much better than having to put the top up.
If you can drill holes in plastic with a portable drill, you have all of the skills necessary to install it.
Since the aeroscreen uses the same holes as the factory one, they plastic already has little guide points in it for you to drill. Just make sure you start with a small bit and work your way up.
