AFR and a test pipe/exhaust
I plan to install a new Berk tp and the HKS exhaust. I have been reading through a few threads and from what I understand, these pieces cause a leaning of the air to fuel ratio. Does anyone know if there is any danger associated with having these pieces installed and not tuning the car's AFR?
I will dyno it one of these days, but won't know the AFR for a while. Will I be ok until then? This is on a MY01, which are known to run a bit rich anyway. So yea, any feedback?
If you are NA, you are already running a bit rich as all S2000s do. So what if a mod makes you run a bit leaner. Probably a good thing. Did you know that people put on VAFCs and the older S2000s went with newer ECUs just to lean them out? Your mods aren't even going to be that dramatic.
