Aftermarket Rotors
Are aftermarket rotors lighter than stock? I see J's Racing, Spoon, and several others make rotors for the S but none mention actual weight. How much do the stock rotors weigh?
One must ask: Is a little unsprung weight savings worth the possible downside of having less mass in a brake rotor? It is the mass of the rotor that dissipates heat and stops the car. The OEM rotors can withstand a great deal of abuse, even in track conditions. Don't take chances with your brakes.
I've had to replace my OEM rotors. Currently I am running cobalt rotors. I got a very good deal on them, but after awhile I will need to replace these as well. ( I run agressive pads and auto-X quite a bit)
Many people I have spoken with have had good luck with NAPA rotors. Any thoughts or comments?
Originally Posted by 04NickySP2,Jun 14 2007, 09:38 AM
ummm rotating mass is very important.
I'm surprised there is no information on rotors other than the much debated slotted or drilled
. I'm sure someone has come up with some good rotors that are lighter than stock and without compromising strength.
aggiedave98
Apr 11, 2008 09:02 AM
kaansahbaz
Feb 12, 2007 09:37 PM
