aggressive gap for champion coppers?
I have found a couple people in the search saying that if you use Champion plugs they work quit well but you have to gap aggressively. These guys had turbos however so do I still need to gap the Champions aggressively for NA? If not, what is recommended, OEM gap?
Thanks
Thanks
People with FI need to use different temp plugs and/or gaps. Stock is 0.044"
http://www.championsparkplugs.com/results_...sp?AAIA=1434327
Thanks,
I didn't realize napa had the plugs. I needed to get the boschs out today and neither of the two parts stores (advance, autozone) had the ngks I wanted.
I went with 13 pounds on the torque for the plugs. i noticed there is a bit of a debate at times about this.
thanks for this info
2QYK4U
Nov 17, 2006 04:52 PM
