Air leak in the ragtop
Old Oct 2, 2001 | 06:54 PM
1badS2000's Avatar
Default Air leak in the ragtop
Just took my car in to get an air leak checked out, gillman honda did a fine job aligning the top, didnt have to order or install any parts, done in 2 1/2 hours, but they also drove my car for 20miles, i thought that was really shitty, when i took the car on the access road to show the service writer, the air leak it took maybe 2 miles, couldnt tell if they took my car joyridn, but i wouldnt doubt it, i wrote the mileage on the palm of my hand thats how i was sure.
Old Oct 3, 2001 | 04:48 AM
av8tor2's Avatar
When I take my car to the deal I always reset the trip "b" to zero and flip it back to "a". It shows you how many miles they drive your car without getting ink on yourself.
I had the same problem and the replaced the latches and it fine now, the air leak occurred at 60+.
P
Old Oct 3, 2001 | 05:21 AM
Don_Darizz's Avatar
Just a quick question... I hear air leaking in at about 88+ is this normal or should I have them check it out..
I just figured it was normal for that high of speed... Please let me know..
The Don
Old Oct 3, 2001 | 05:31 AM
stocks2k's Avatar
[QUOTE]Originally posted by av8tor2
[B]When I take my car to the deal I always reset the trip "b" to zero and flip it back to "a".
Old Oct 3, 2001 | 05:42 AM
cdelena's Avatar
The times I have detected a air leak I simply used the silicone lube on the seals as specified in the owners manual. Since my car does not seem to have a problem requiring adjustment using the silicone has always solved the problem.
Old Oct 3, 2001 | 06:02 AM
Don_Darizz's Avatar
I used the silicon... I just have a feeling if I tell my dealer the roof leaks some air when I am doing 100, they are going to say it is normal...
Just wanted some insight on whether or not it is normal... Or do I need to adjust the top and/or latches..
Old Oct 3, 2001 | 06:36 AM
1badS2000's Avatar
hey don itrs def. not normal, i would hear mine at 50mph plus and i had to take it to about 80mph becuase the service wrtier said he didnt hear it, and about 75 to 80mph he says oh that noise
Old Oct 3, 2001 | 09:20 AM
av8tor2's Avatar
Then, you look at the Service Write up, and it has the miles the car had on it when you took it in for service...
A few miles is okay....over 10 is a no, unless there is a good reason to drive my car that far for service....(wouldn't know what that reason would be, but better be a good one...)
Plus I don't think the tech would reset both, and if they did, I would have to question them why the trips were reset....
P
Old Oct 3, 2001 | 11:39 AM
wirejock's Avatar
I wouldn't want the service tech cruising at 100 mph to find a noise in my car.
Others on this board hand write the milage on the service ticket where it's clearly noticeable, then they place a sticky note on the dashboard with the same number.
Jsmakr
Jul 16, 2008 09:24 AM
millenniumRX2
Aug 21, 2007 05:32 PM
geoff2005
Jan 26, 2006 05:37 PM
lilbizzyazn
Mar 10, 2005 01:35 PM
ninegrand
Jul 12, 2003 03:46 PM
