amuse stlye lips installation plz.....
It really doesn't matter what order you follow to put the cylinders and screws in. When you have the bolts stuck through the cylinders, there should be about 1/2" or slightly more of thread sticking through the end of the cylinder. I realize that if you just start pushing up and trying to thread the bolt, it is very hard. You must somehow get a finger up and above the metal bolt anchor that's on the undertray and hold it down as you try to thread the bolt. Otherwise, you just keep pushing the anchor away. Once it begins to thread, it'll be smooth sailing.
"screw the two screws at the wrap around, then in stall the two outter cylinders, which I had difficulties in." ----- From the sounds of this, your bolts are not going through the centers of those cylinders. You will lose the cylinders eventually.
