Amuse Style Lip Instructions
Old Nov 27, 2003 | 07:55 AM
NFRs2000NYC's Avatar
Default Amuse Style Lip Instructions
Does anyone have a link or something for the step by step installation of the amuse style lip (got mine from spugen). Thanks in advance.
Old Nov 27, 2003 | 08:02 AM
darkknight1999's Avatar
Its very easy. Did you get the spacers and screws? You should have gotten 4 spacers and a set of screws for the under side. These will replace the stock bolts on the underside of the front bumper. These bolts are longer. You will also need automotive grade doublesided tape and a few screws for each side by the wheels.
I can help you with the instill over the phone if you'd like.
Old Nov 27, 2003 | 08:08 AM
WEll.......I have the spugen lip, so all the tape is already on, and it came with 4 spacers and 4 screws. I need to know what goes where, drill what, etc....Cause I am clueless on this....pics would be great too.
Old Nov 27, 2003 | 04:15 PM
03_AP1's Avatar
its very very easy.
I don't have pics, but this should suffice:
1) Remove 4 under bumper screws from your car.....the two most outer ones, and the two on either side of the centre screw. These screws go all along the bottom of your bumper, there are like 7-8 of them, but like I said, remove the 4 ones that I mentioned.
2) Test fit your lip, prop it on with anything you have, books, magazines, blocks of wood, tape....whatever
3) Attempt, and I mean attempt, to draw spots where you wanna drill holes in your lip.....it doesn't have to LOOK perfect, do whatever it takes to make sure your drilled holes line up with those holes you just removed those factory screws from.
4) The spacers...the two longer ones go near the ends, the the shorter ones go on the two either side of the centre.
5) If you got the "anti-gap" spacers (flat, black funky shaped do-hickies)for the wheel wheel, screw them on to your lip using the BOTTOM pre-drilled hole. (these holes were the only pre-drilled ones) using the shorter wood screws.
6) Remove the stipping off the double sided tape
7) Screw that sucker on!! Use the longer bolts and spacers for the outer holes, and the shorter spacers and bolts for the inner holes either side of centre, they'll screw right into the factory holes from which you removed those factory screws. Use the remaining wood screws to screw on the fender well sections, using the TOP hole lined up with the factory hole on your wheel fender, intended for the OEM lip.
CONGRATS!! YOUR DONE!!
If any of this is unclear, let me know, and I'll try to explain better
Old Nov 28, 2003 | 12:49 AM
Thanks a million 03_AP1......
One more thing......people said "make sure you screw the lip into the wheelwell....what does that mean?? The kit only came with 4 spacers and 4 screws.....
Also, my kit didnt come with washers for the wheelwell, what can I use to make a makeshift one.....I really want as little gap as possible....
---how do I install this....where do they go???
Thanks again bro.....
Old Nov 28, 2003 | 06:17 AM
03_AP1's Avatar
where the lip curls around at 90 degrees on the very ends of the lip....that hooks around and screws into a small hole thats on the inside trim of your wheel well.
You should have got 4 small wood screws, and the lip should have 2 small holes drilled on eacg end piece of your lip.
The spacer I got was a 1/4 thick piece that fits inside this curled part, like a spacer. The bottom drilled hole is for screwing on the spacer, then the top hole should line up with the hole on your fender, like I mentioned.
any more questions, let me know
s2k_9000rpm
Oct 22, 2006 08:04 PM
JspecVtec
Sep 2, 2004 10:33 AM
nigashorty
Aug 18, 2004 12:47 PM
ROGUE3308
Apr 15, 2004 07:02 AM
amongmany
Jul 7, 2003 05:20 AM
