another 4.56 question
Old Sep 22, 2005 | 11:19 AM
dyhppy's Avatar
Default another 4.56 question
if the gears make u rev faster up, does it drop faster down?
sort of like another flywheel?
is the 4.56 gear heavier than stock? (inertial force)
Old Sep 22, 2005 | 11:51 AM
Wisconsin S2k's Avatar
when your revs drop down, they have nothing to do with the gearset. you have the clutch pushed in or the car in neutral, which means the engine is NOT spinning or connected to the driveshaft/diff.
Old Sep 22, 2005 | 11:57 AM
steven975's Avatar
no, the drop in revs is a function of the weight of your clutch/flywheel. gears won't change that.
Old Sep 22, 2005 | 12:08 PM
dyhppy's Avatar
ur totally right. i'm sorry, i didn't think of it that way. i meant, when u let off the gas but don't disengage the clutch. will the revs drop faster?
Old Sep 22, 2005 | 03:25 PM
not that i know of.
Old Sep 22, 2005 | 03:59 PM
dyhppy's Avatar
thnx Wisconsin
Old Sep 22, 2005 | 08:06 PM
Grazhoppa's Avatar
An unrelated question for my own education: Will the 4.57 gear cause the rpm to be higher at a certain speed than the stock gear? For example, driving with the stock gear at 80 mph in sixth gear, the rpm would be around 4500-5000 rpm. With the 4.57 gear, would the rpm be higher or lower than the stock gear at the same speed in sixth gear?
Old Sep 22, 2005 | 08:12 PM
YellowS2kPwr's Avatar
Higher in every gear
Old Sep 22, 2005 | 08:36 PM
Sideways's Avatar
Originally Posted by Wisconsin S2k,Sep 22 2005, 04:25 PM
not that i know of.
It will be like driving in 5th gear instead of 6th. Does 5th drop faster?
wicked357
Jul 30, 2012 01:44 PM
oldskooleskimo
Dec 12, 2009 04:10 AM
js2k2005
Jul 21, 2009 12:25 AM
thorax
Jun 22, 2007 03:14 AM
Cyber Logic
Jul 1, 2001 08:02 PM
