Any ideas to increase interior space in a S2000
Old Aug 31, 2009 | 05:12 AM
gilbroyer's Avatar
Default Any ideas to increase interior space in a S2000
I would like to purchase a s 2000, and have driven one, but since I am 6 feet 3 inches I do not fit very well. Does anyone know of anybody who has made some interior modifications to increase the space to the left of the clutch pedal and raised the stearing wheel (there is no tilt wheel). I would like to know if this is possible.
Thanks
Old Aug 31, 2009 | 05:30 AM
b1indsamurai's Avatar
You can try modifying the seat rails so you sit lower or get an aftermarket seat. That should give you some leg room and remedy your steering wheel problem.
Old Aug 31, 2009 | 05:32 AM
jeffbrig's Avatar
You can remove the dead pedal if you want....the steering wheel can be adjusted a bit by shimming the mounting points on the steering column (there are some threads showing this).
Old Aug 31, 2009 | 05:43 AM
deathsled's Avatar
If you remove the plastic kick panel that covers the ECU on the left side of the foot well you can pick up another half inch or maybe full inch of foot space. I removed it in my S (because I was swapping ECUs a lot at the time) and never looked back, it was a lot more room (for the S, haha)
Old Aug 31, 2009 | 09:38 AM
spook's Avatar
Aftermarket seat with low rails is your best bet.
Old Sep 1, 2009 | 07:56 AM
centralcoastbuc's Avatar
BYS seat rail was one of the best mods I did. No more neck aches and I can see the tack now.
Old Sep 1, 2009 | 09:21 AM
EVAN&MONICA's Avatar
im 6'3" I fit just right in my "S" try moving the seat back and leaning it back all the way ?
Old Sep 1, 2009 | 12:07 PM
//steve\\'s Avatar
A bucket seat will give you a significant increase in space. yes it's a little more of a pain to get in and out of but it's worth it.
Old Sep 1, 2009 | 02:43 PM
HornedFrog's Avatar
drive with your shoes off!
Old Sep 1, 2009 | 02:52 PM
deathsled's Avatar
you must have short legs or arms and a huge torso or something I'm only 6'0" and with the seat moved back and seat reclined as far as it would go I still wanted more room leg room and distance between me and the steering wheel.
Wojofoo
Sep 27, 2015 11:09 AM
RichwiththeS2000
Mar 11, 2011 11:29 AM
diddiyo
Dec 25, 2010 05:44 AM
slimjim8201
Jun 1, 2006 09:08 AM
Rich Tilden
Feb 16, 2004 11:20 PM
