Any quite exhaust for turbo S
Old 10-30-2004, 07:27 AM
speedy4cyl's Avatar
Default Any quite exhaust for turbo S
Anyone own a turbo S and have a quiet exhaust. I am a little tired of all the noise. Any clues or different tips and mufflers I can use to go with the 3 inch pipe to quiet it down some.
Old 10-30-2004, 08:03 AM
03_AP1's Avatar
what exhaust are you using now?
I always thought that turbos will quiet down your exhaust???
Anyways, PM s2kwhite - he has a turbo'd s2k and went from an Invidia to a T1R.
He might be able to provide some insight on the difference between the two.
Old 10-30-2004, 08:33 AM
speedy4cyl's Avatar
I am running ultimate racing's exhaust. Little too loud for my taste.
Old 10-30-2004, 08:59 AM
msm_s2k's Avatar
Which version of the Ultimate Racing exhaust are you running? I've heard that the dual setup with the stock style (rather than n1) exhaust is pretty quiet.
I hope it is. I'm switching to the 3" ultimate racing dual from the JIC single. The JIC is loud ... and I'm tired of getting pulled over for it.
Old 10-30-2004, 12:41 PM
speedy4cyl's Avatar
I have the single 3 inch
Old 10-30-2004, 12:47 PM
Blkturbos2k's Avatar
If you want to keep the power then you might want to stay with what you have or get a exhaust cut-out so you can run a open down pipe when you want to run and a stock exhaust any other time
Old 10-30-2004, 12:57 PM
speedy4cyl's Avatar
What if i keep the 3 inch and change the tip That should still keep good back pressure and not mess with it too much.
Old 10-30-2004, 01:03 PM
azndrunkyoon's Avatar
just get a three inch straight out best for turbo cars anyways
Old 10-30-2004, 02:26 PM
speedy4cyl's Avatar
thats what i have but i want something to quite it a little so changeing the tip and leaving the pipe may work out ok.
Old 10-30-2004, 02:33 PM
speedy4cyl's Avatar
How is that apex single exhaust anyone have that. Is that 3 in all the way back?
Quick Reply: Any quite exhaust for turbo S
