Anyone Recall How To Make Top Go Down While Moving
Old Jul 7, 2004 | 06:08 AM
thereisnospoon's Avatar
Default Anyone Recall How To Make Top Go Down While Moving
i know its a wire somewhere that I need to discconnect so that I can pull the e-brake up once click and be able to put the top up or ddown while creeping along in traffic...
anyone?
thanks!
Old Jul 7, 2004 | 06:13 AM
ruexp67's Avatar
I do. See if the link in my sig is still working
Old Jul 7, 2004 | 06:16 AM
ruexp67's Avatar
Nope.
You cut a wire (or push out the pin) from the top module located under the passenger side dash.
Take off the panel that is where the glovebox should be. In the middle of the passenger area and behind that panel are two connectors. The connector on the right has the wire you want to remove. It is white with a black stripe and silver dots. It is the same wire used to provide the speed signal to the Modifry DCI. Either push the pin out of the connector or just cut the wire. If you have the DCI, then cut the wire between your tap/splice and the connector and your DCI will still work properly.
Old Jul 7, 2004 | 06:34 AM
ruexp67's Avatar
I also fixed the link in my sig.
Old Jul 7, 2004 | 08:06 AM
sweet - thanks!
Old Jul 7, 2004 | 09:17 AM
ruexp67's Avatar
np
jlev2ki
Aug 25, 2005 05:01 PM
nazaracing
May 7, 2005 02:04 PM
NavinRJohnson
Oct 31, 2004 02:26 PM
S2WOOOW
Dec 19, 2002 01:39 PM
nEVERCLEAR
Feb 14, 2002 07:09 AM
