AP1 Softtop Latch Question
Old Dec 22, 2005 | 11:26 AM
Buckeye3d's Avatar
Default AP1 Softtop Latch Question
I used to own an 05 S. When you unlocked the softtop latches they would click shut and be held in place while you opened the top. Today I had the chance to checkout a used 02 and when I unlocked the top the latches did not click shut...they just dangle there as you open the top. Is this normal? I hope that all makes sense.
Old Dec 22, 2005 | 11:52 AM
vtec9's Avatar
I think I get what you're saying. mine just dangle there. Its not a problem when opening the roof, only when closing. I have to manually stick the latches in the striker or they won't line up.
Old Dec 22, 2005 | 12:11 PM
xviper's Avatar
No, this is not normal. It should be like your 05. When you close them out of the strikers, they should stay closed. Sounds like the button springs are broken or gone. If you manually retract the button, it should hold, right?
Old Dec 22, 2005 | 05:08 PM
vtec9's Avatar
I think I misunderstood.. I've only opened the roof twice I don't know what I'm talking about
Old Dec 22, 2005 | 08:20 PM
MASTERS2K's Avatar
i own an 02, latches work just like the 05's
Old Dec 23, 2005 | 02:39 AM
Buckeye3d's Avatar
Thanks for the confirmation something is wrong.
Old Dec 23, 2005 | 06:29 AM
Buckeye3d's Avatar
Forgot to ask...are the latches something they can replace or does it require a whole new softtop?
Old Dec 23, 2005 | 06:35 AM
Zeemz's Avatar
No they can replace the latches only....
Old Dec 23, 2005 | 06:36 AM
Zeemz's Avatar
Becarful, I read somewhere that someone had the the same problem and they ended up causing a tear in the roof due to the broken latches.
Old Dec 23, 2005 | 06:49 AM
xviper's Avatar
Not cheap, though ............................
http://www.slhondaparts.com/browse.asp?Mod...d=86250-S2A-J01
silveris300wantgone
Mar 1, 2013 11:02 AM
cdubea
Jun 15, 2012 11:40 AM
CrazyCase
Oct 5, 2006 03:50 PM
Ks320
May 6, 2006 09:10 PM
campbuds
Oct 27, 2005 05:21 AM
