ap2 cluster for my ap1?
the cluster doesn't control what rpm your fuel cuts off at. that's in your ecu. I think I've seen people try it and if I remember correctly it didn't work. plus the miles will be different from what you have, its almost impssible to find someone that could change the miles on a digital cluster.
The engine will go to 9k but the tach will only read 8k. The JDM cluster only displays in KM not miles, you need to buy an EDM cluster for that. Also, as mentioned above, your mileage will not be correct as it is stored in the cluster. Finally, the swap is not plug and play, you will need to do rewiring to get this to work correctly.
