AP2 Maintenance Schedule
Old Sep 3, 2010 | 07:32 AM
In The Year S2000's Avatar
Default AP2 Maintenance Schedule
Long story short: I have a 2005 that didn't come with the owner's manual, maintenance schedule, etc...
I found a good link using the search feature (https://www.s2ki.com/forums/index.php?showtopic=153537) but it was posted in 2003...so clearly it is for an AP1. Does anybody know, is there a difference or is this fine to go by? Or, do you know of a link to a maintenance schedule to an AP2. I searched but didn't find anything.
Thanks.
Old Sep 3, 2010 | 09:40 AM
dsthez's Avatar
be sure to do trans service, diff service, oil changes, coolant is ok until 100k but do top it off, do sparks areound 50k, pcv is good as well
Old Sep 3, 2010 | 09:56 AM
hirev's Avatar
just fluids and filters.....a valve adjust as needed or at 102,0000 and no timing belt. no tires to rotate.
there is a cabin filter(i do it annualy), air cleaner (I have K&N), oil changes vary as to length and miles driven, trans and diff fluids and brake fluid flush as needed or 30,000 miles or depends on your values.
lube the top hinges and mechanics, door, trunk, hood latches, watch out for internal tears in the top and look at the modfry fix here.
Old Sep 3, 2010 | 10:07 AM
Cool. I bought the car at 46k and immediately changed the oil, trans fluid and diff fluid.
It looks like the old schedule suggests every 15k for diff and trans, so I'll stick with that. Thanks for the advice.
Old Sep 3, 2010 | 10:11 AM
got.s2k's Avatar
You can go to the Honda Owner's Link website here:
https://www.ahm-ownerlink.com/login.asp?brand=honda
Create a login for yourself and enter your vehicle information. You will then be able to see the Honda recommended maintenance schedule for your car online.
Old Sep 3, 2010 | 10:21 AM
PJCC's Avatar
That's what I use.
Old Oct 21, 2016 | 03:56 AM
CJ2006's Avatar
I know this is an old thread, but I wanted to post a relevant update for everyone.
The link has changed, and there is no longer a need to login, just select year and model. It's now: http://owners.honda.com/service-maintenance/minder
Here's the maintenance schedule for a MY06 S, for example: http://owners.honda.com/service-maintenance/minder?year=2006&model=S2000#mid^AP2146ENW
Both Normal and Severe are view-able, and you can expand all and then print easily for reference.
triddle
Oct 17, 2012 12:37 PM
Jayboy83
Sep 10, 2010 01:44 AM
nzouk77
Mar 9, 2008 09:52 PM
s2k_redhead
Sep 26, 2007 04:23 PM
bruceleeroy
Dec 6, 2005 08:35 PM
