Ap2 soft top window leaking water
Old Jul 20, 2018 | 12:37 PM
Jpee's Avatar
Default Ap2 soft top window leaking water
i just noticed this on my S. The back window on my soft top leaks water! Im pretty sure there are drains where the water is leaking but im not sure. Im talking about that part behind the seats where the soft top folds and sits on when putting it down.
my main concern rn is if the water actually does go away there. Also how should I approach on fixing this?
I need a solution asap! Thanks!!
Old Jul 20, 2018 | 01:18 PM
silenc3x's Avatar
Where does it leak water? It might drain into the normal places. See comment below from Billman250:
The ends of the rain rail empty water into the black buckets.
The buckets have about a 5/8" tube exiting from them, with a little bar across the hole to prevent large items from going down (like a sink drain)
These holes are commonly blocked with acorns, pine needles, and dirt.
I found one so packed with soil, it had stuff growing in it.
You can put the top down, and using a penlight you can see right into the buckets.
This video helpful:
This one too, as it goes over leaking:
gregasorous
Sep 6, 2017 02:16 PM
zedward88
Jun 4, 2010 04:41 PM
vtec9
Sep 8, 2008 04:53 AM
geoff2005
Jul 13, 2006 08:00 AM
Jonas Hedvall
Nov 29, 2000 09:39 AM
