Attn Wisconsin
Old Sep 11, 2005 | 10:15 PM
dyhppy's Avatar
Default Attn Wisconsin
some people say that an ap1 with 4.44 gears is like an ap2. does that mean a ap2 with 4.57 gears will not benefit like an ap1 would? what is the best all around gear to get for ap2?
thankx
Old Sep 11, 2005 | 10:32 PM
SilverKnight's Avatar
and where can i get 4.57? ricks is out....when will it be back? also all i need to do is buy the gears and a mecahnic can do the install no probs? what I mean is like does the diff need to be replaced or somethingm core?
Old Sep 11, 2005 | 10:37 PM
R.P.M's Avatar
Ricks told me that they should have the group buy on these at the end of this month. Yes there is a $1K refundable core charge if you buy them through Ricks.
Old Sep 11, 2005 | 11:45 PM
dyhppy's Avatar
thought i would link this for those interested in gear mods for our big brother, the NSX.
http://www.nsxprime.com/FAQ/Performance/gears.htm
bottomline, theirs are much more expensive than ours, but they love it.
Old Sep 12, 2005 | 07:06 AM
xviper's Avatar
Hold on there, big fella! Not just any mechanic. ONLY a mechanic who is experienced in doing rear differential ring and pinion gears. If you get just "any" mechanic to do this, this could turn out to be your WORST nightmare and make you wish you have never heard of "gears".
A slight ammendment, if you will. This core charge is only if you elect to buy a set of gears that has been installed into an existing pumpkin. They send you the whole pumpkin with gears inside and you send them your pumpkin with your old gears inside. If you simple buy the gears, there is no core charge. If you send your own rear diff to Rick's to have Ganley put in the gears, there is no core charge, but installation fees and shipping charges apply.
(Now, I'm pretty sure this is the way it is. If I'm wrong, please slap me silly with a wet noodle. )
Old Sep 12, 2005 | 08:45 AM
Wisconsin S2k's Avatar
thankx
an ap2 is like an ap1 with 4.27 gears. if you ignore the heavier wheels and the lowered redline.
otherwise, i would think that between a 4.57 ap1 and 4.57 ap2 the difference would be negligible. just like the stock car's differences are negligible. however, due to the lowered redline on the ap2 you may find yourself having to shift much sooner than you'd prefer.
use the gear calculator to figure it out.
http://www.reverendsgarage.net/index.php?c..._calculator.php
Old Sep 12, 2005 | 08:47 AM
ricks is the only place to get 4.57's. if you buy the gears but don't want to send your diff to rick's to get it installed, be certain you find a mechanic who is good at doing RWD gear installs. doing gears on an S2000 is an art more so than a technical experience. there are things the installer MUST know before installing the gears. (for example. to use all the OEM specs in the helm manual for a gear install, EXCEPT the backlash settings. the backlash should be set to .006)
otherwise you can do the $1000 core exchange where they send you a diff so you can get just the diff installed by any decent mechanic or honda dealer. then when you send your diff back they refund that $1000
IrishS2k
Mar 30, 2013 07:03 PM
08s2000CRbackinblack
23
Feb 15, 2013 06:09 PM
MBHs2k
32
Aug 12, 2010 05:26 PM
IrishS2k
Orlando
Mar 30, 2009 06:03 AM
dagostino777
May 23, 2007 05:45 AM
