Is average RPM driving not good?
Old Apr 27, 2008 | 03:12 PM
  #121
PanteraKitty's Avatar
Originally Posted by RED MX5,Apr 27 2008, 12:37 PM
Since most wear takes place during dry starts, I think pre-oilers might make a significang difference in wear, and in colder areas I think a block heater would help too, but that's just my thinking and not something I've actually tried.
OTOH, anyone who is worried about engine wear should probably spend some time looking through the S2kI's "The Oil Journals." Lots of good information here from RoadRage (lubrication guru) and XViper.
I've heard that the worst thing you can do is start your engine. I have also seen an Accusump system used as a pre-oiler. Just close the valves before you stop the engine and open the valves just before you start it.
Old Apr 27, 2008 | 05:04 PM
  #122
RED MX5's Avatar
Accusump claims a 50% reduction in cold start "scuffing wear." Accumulators like the Accusump also prevent loss of oil pressure during cornering or hard braking.
I've also recently seen some info on a pre-oiler that used some kind of electric pump or motor to provide oil pressure before a clod start, but I don't recall where I saw it.
Has anyone lost an S2000 engine due to oil pressure loss during high G cornering or braking (other than cases where the oil level was obviously too low)?
Old Apr 27, 2008 | 05:10 PM
  #123
RED MX5's Avatar
Originally Posted by qbmurderer13,Apr 27 2008, 04:34 PM
isn't the reason mpg in the highwy is higher because there's less throttle required? if mpg is based solely on rpm other than throttle position then highway mpg would be worse. so then wouldn't you be better off in a gear that you can apply less throttle but still be below 3.5 rpm? red maybe you can shed some more light on this lol
The reason highway mileage is higher than "city," is becuase on the highway you tend to maintain a constant speed. In stop and go traffic, you waste a lot of energy slowing down with the brakes, and have to burn more gas to get back up to speed every time you use the brakes to slow down. In a way, the brakes could be seem as the biggest waste of gasoline, becuase all the energy that is converted into heat by the brakes is a total loss. In general, the best way to increase mileage is to maintain your momentum.
BTW, I think MikeGarrison already said the same thing earlier, only in somewhat different terms.
Old Apr 27, 2008 | 07:34 PM
  #124
qbmurderer13's Avatar
and to maintain momentum you have to apply a certain percentage of throttle. so would it be better to drive at the lowest rpm possible with more throttle? or in a lower gear with higher rpms and less throttle? on the highway the rpms are generally higher than city driving, and throttle percentage is lower. if in the city I accelerate at 30 percent throttle but don't take it past 4k rpm, that technically translates to: more throttle, less mpg. regardless of rpm? of course if we go into the 6k+ rpm territory it might be different. I'm just thinking it would be better to cruise in 5th when your doing 40mph since you don't have to apply as much throttle to maintain that speed and the rpms are only slightly higher, similiar to what you would see on the highway.
Old Apr 28, 2008 | 03:14 AM
  #125
Ualreadykno's Avatar
Well what determines wether or not I drive in higher gears at 45 or 50 mph would be if im on my bluetooth or not! LOL. A lot of my friends complain about the engine noise although I LOVE it!!
Old Apr 28, 2008 | 05:42 PM
  #126
mikegarrison's Avatar
Yes. Banked oval tracks and racing slicks have eaten a few S2000 engines due to G-induced oil starvation. The evidence for this happening in other circumstances is more spotty.
Old Apr 28, 2008 | 09:37 PM
  #127
RED MX5's Avatar
I had no idea anyone was running an S2000 on any kind of banked oval. Places like MIS have such steep banking that you can't even stand, and I believe oil can all end up on one side of the pan if the car is *stopped* up on the steepest part of the banking.
Are any of the guys running accumulators or dry sumps?
Old Apr 28, 2008 | 11:02 PM
  #128
It's been tried. Neither is especially practical in a car that sees any street duty at all. Accusumps are notorious for occasionally puking oil all over the place, and re-engineering the S2000 engine for a dry sump is a major undertaking. A few have tried it, but I haven't heard of any that were considered big successes.
FluKy15
Jul 10, 2010 11:00 AM
PJD
Jun 17, 2008 09:02 AM
xs2kFanaticx
Nov 7, 2006 09:26 AM
S4_dukar
Oct 31, 2003 07:23 PM
zero_to60
Apr 30, 2003 11:46 AM
