Back Brakes Rubbing
Fellas,
My rear brake pads seem to be rubbing against the rotors as I drive. The hand brake is not activated. Any suggestions as to unsticking them??
Thanks
The car was parked for about a month with the hand brake up though which I know is not advised. OOPS
Thanks
Originally posted by hygiene boy
I was under the impression that he didn't do anything to the brakes, just had the car sitting for a month.
The wheels are properly installed.
To confirm that the rear brakes are really dragging as you drive, try jacking up the rear wheels and turn the wheels by hand. Listen if the rear pads if they're the real culprit. If so, you can either do a parking brake adjustment or check if your caliper pins are stuck. I think your problem is with the caliper pins. Take out the caliper pins and clean them throughly. After cleaning, lube them up and put it back together. That should solve your problem. HTH. Goodluck.
