Back End Is Easy To Kick Out...
First thing I would check is for spring spacers as everyone else suggested. Jack up your car, take off the wheels, and look for a plastic piece that sits in between the springs. Do a search for spring spacers and I'm sure you can find a picture of it, but it is obvious when you see it.
I was also having problems with the car when I first got it (used), I spun out twice within a month. The previous owner had worn out S02's on the front and too small 225 S03's on the back, and completely screwed up alignment. Make sure you get the right size tires, and most importantly GET AN ALIGNMENT at a recommended race/tune shop. Don't go to a Firestone or similar place because from my experience they just don't know what they're doing. I would go ask people in the regional communites for their recommendation on a good alignment shop. Once I got the right tires, and alignment the car is light years better. It'll still oversteer though, thats just part of a lightweight RWD car. But the car actually feels like it has grip now.
well there is a thing plastic piece at the very bottom of the spring that it rests on. its black and thing... not much els I can say about it. I did not take off the wheel or anything just looked on it. let me know what it is. thanks
Originally Posted by mav,Jul 8 2004, 10:39 AM
There are mods out there that will improve the handling of the car but before you go that route, you should learn how to properly drive it first.
AWD cars tend to understeer, and are able to put down power earlier in a turn because of their traction advantage when accelerating. I'm guessing that you are giving too much gas and doing it too early in a turn. This will "saturate" the grip of the rear tires causing them to slide. Learning to turn with the throttle this is one of the funnest and useful things about RWD. There are other causes of oversteer too, but learning all this is best done and taught at a school.
Just curious are there any parts to make it harder to kick the back end out? Also how would someone go about improving the skid pad test? I have read that the 04's pull around .88g and the 00-03 pull around .92g on the skid pad. How does this translate to the 04 being the better handler? Thanks
Handling is really about if the car behaves in a "good" way with respect to road conditions and driver input. This is something that requires some driver feel and education to sanely comment about, to decide on the right modifications. If you do get to an autocross find an experienced S2000 driver, or any other car, and get a ride along. You'll be amazed what an experienced driver can do with any bone stock car. My first year of autocross, I would get my ass handed to me in raw time by this incredible driver in a stock Hyndai Accent, in all it's 100 hp glory.
There are definitely parts that will make the car handle better. But we are talking about tweaks that will only be noticed when driving near the limit, i.e. on the track or autocross. It is better to have more driver experience to really know what you want out of the car. If anyone is hitting those limits on public roads, they can could do with some driver training or be locked up for driving at unsafe speeds way above any typical speed limits.
Originally Posted by Elistan,Jul 8 2004, 07:44 AM
Completely the opposite situation with my '04. It understeers like crazy, even after an alignment to increase front camber. No doubt it would be fast around a race track, but driving it around the city is rather frustrating.Things to check:
- Tire pressures
- Tire conditions (Don't "know" they're okay, actually check the tread.)
- Alignment
I experienced understeer untill I had my alignment done.....the alignment from the factory was CRAP....it was way out of factory specs....The MY04 is like the MY00-03 you should really have the alignment done.
It's possible that a really bad alignment could make this car oversteer. Compared to my last car the MY04 is hard to break the back end loose, and locks down very quickly once you do.
