Bigger Xbrace bolt
Old Jan 2, 2004 | 01:51 PM
Y2K1S2K's Avatar
Default Bigger Xbrace bolt
when i installed my xbrace i stripped both the inside and one of the bolts...is there anyone here who has or knows where to get an 11mm xbrace bolt? everything else being the same...execept bigger...i will then use a die and make new threads so i can torque it again...
thanks
Old Jan 2, 2004 | 02:06 PM
turbo_pwr's Avatar
have you tried just taking the bolt to a hardware store?
Old Jan 2, 2004 | 04:42 PM
Y2K1S2K's Avatar
ive called around for the regular spoon bolt and no one has it...its very fine thread and a rare size...im assuming 1 up will be even MORE rare and even harder to find
Old Jan 3, 2004 | 05:25 PM
Y2K1S2K's Avatar
bump
Old Jan 3, 2004 | 06:02 PM
ninegrand's Avatar
You would be suprised at the variety of bolts a quality hardware store will have in stock.
That being said you might have a challenge on your hands getting everything done correct and getting the frame threaded to fit the new bolt. If you have the correct tap & die set you should be able to get it to work, just need to find a fine thread bolt to work from the way it sounds.
shaner
Nov 2, 2012 07:21 PM
itS2Krazy
23
Mar 7, 2006 09:57 PM
krysdafur
Oct 30, 2005 02:28 PM
douge
Apr 12, 2004 04:32 PM
Incubus
Nov 11, 2002 11:25 AM
