Blown engine
Old Aug 22, 2008 | 05:38 AM
Blacknot's Avatar
I cant believe how many people run their cars out of oil. It truely amazes me. I have a friend that has already done this twice in the 4 years i have known him
Old Aug 22, 2008 | 06:08 AM
g352s2k's Avatar
worldautoparts.com
Old Aug 22, 2008 | 08:20 AM
c0ok0o's Avatar
Yea, you most likely spun a bearing which probably ripped a hole in the crankshaft. Exact same thing happened to my friend. And if that is the case, your best option is to just replace the engine.
...go w/a used engine btw.
Old Aug 22, 2008 | 08:47 AM
GT_NFR's Avatar
I agree, you can find some great deals here and have a drop-in for less than $4500.
Old Aug 22, 2008 | 08:59 AM
Jimmies's Avatar
Originally Posted by sosooo,Aug 21 2008, 06:13 PM
I double clutched
You've seen the Fast and the Furious too many times. Synchronized transmissions make this unnecessary.
Old Aug 22, 2008 | 09:41 AM
thebig33tuna's Avatar
double cluthing is good, you put less stress on the synchros .. esp if you're skipping gears ( 2-4 for example..)
read for more info:
https://www.s2ki.com/forums/index.php?showtopic=237209
https://www.s2ki.com/forums/index.php?showtopic=372717
nice fast and the furious reference though
Old Aug 22, 2008 | 06:30 PM
mmm def's Avatar
How do you spin a bearing? Not being a smartass, I don't want to wreck my engine.
Old Aug 22, 2008 | 07:15 PM
SCCS2K's Avatar
10500 for a new engine? Sounds a little high...Majestic has it for less than 5K, brand new. Or am I reading this wrong?
http://www.hondaautomotiveparts.com/auto/j...NSMISSION++ASSY.
edit - sorry, link doesn't work. select "engine/transmission assembly"
Old Aug 23, 2008 | 07:29 AM
clag's Avatar
Oh jesus, please, let's not start down that path for the 50th time.
Old Aug 23, 2008 | 09:23 AM
qbmurderer13's Avatar
When you run your car low on oil the rod bearings that connect to the crankshaft arent getting any lubrication or getting cooled down by the oil so they end up failing and you end up with a blown engine block. You should be checking your oil at every fill up.
