Bogging s2k
Hi everyone, I'm new to the page. But I currently have a 07 that has and issue when every so often when just cruising the car will bog down really hard and act like it's going to die untill I engage the clutch then it goes right back to normal
I'm betting you meant disengage the clutch but we'll figure it out.
(Clutch is disengaged when you press the clutch pedal.)
Or we will try once you let us know what's going on. "Just cruising" means what? Speed? Gear? Fuel used and how fresh? Rpm? Gear? Temperature? Oil level? Mileage? How often driven? ...
-- Chuck
(Clutch is disengaged when you press the clutch pedal.)Or we will try once you let us know what's going on. "Just cruising" means what? Speed? Gear? Fuel used and how fresh? Rpm? Gear? Temperature? Oil level? Mileage? How often driven? ...
-- Chuck
Best case, plugs, coil packs, or injectors.
Worst case, burnt exhaust valves: https://www.s2ki.com/forums/s2000-un...2A%2A-1060900/
anorexicpoodle
Oct 22, 2018 04:20 PM
