Boost Gauge For s2000...looking for alternative to the pillar mounted pod.
Old Jan 22, 2004 | 04:40 PM
squibb's Avatar
Default Boost Gauge For s2000...looking for alternative to the pillar mounted pod.
I do not want to mount a boost gauge on my pillar becuase I do not want people to see an extra gauge. Does anyone make a holder that would hod a 2" guage and replace the driver side A/C , Heat vent ? Or is there any other alternatives.......keep in mind I want to see the gauge. I do want mess around with cutting the dash either. Thanks.
Old Jan 22, 2004 | 05:01 PM
ruexp67's Avatar
Rick's has the guages in the radio door. Not sure if it's still for sale.
Old Jan 22, 2004 | 05:41 PM
Jip69's Avatar
I dont think rick is making those gauge's anymore for the radio door, but u can check out www.defi-shop.com and they have like some heads up displays and stuff.....may interest u.
JP
Old Jan 22, 2004 | 06:17 PM
fperra's Avatar
Check out the for sale forum, I have a Blitz boost and oil pressure guage for sale. these gauges are only about 1/2 inch deep and fit in the radio door.
Old Jan 22, 2004 | 08:14 PM
AusS2000's Avatar
I've got the Defi HUD Boost Gauge for exactly the reasons you mentioned. Looks stock when off and extremely cool when running.
They don't make it anymore, but someone was selling one a while back. Do a search in the For Sale section.
Defi also have a combo HUD gauge that does speed, rev, and temps and pressures. That's my next addition.
Old Jan 22, 2004 | 08:17 PM
AusS2000's Avatar
http://forums.s2ki.com/forums/showthread.p...&highlight=defi
Old Jan 22, 2004 | 09:21 PM
Slows2k's Avatar
It's most likely not what you are looking for, but here's mine. You have to remove the back of the mode switch and lightly open up the trim bezel. The mode switch doesn't work afterward. But you can go back to stock. I picked up the mode switch used to save my original.
Old Jan 23, 2004 | 06:02 PM
squibb's Avatar
[QUOTE]Originally posted by Slows2k
http://gallery.s2ki.com/imagecatalog/image...geview/96541/6/
Old Jan 23, 2004 | 06:10 PM
Slows2k's Avatar
None of the functions of the audio switch work. you have to remove the circuit board behind it.
As far as the Toda goes, I had it before the SC, Any 5HP gain is hard to be "felt". It did seem to pull smoother through VTEC when the car was NA. I haven't dynoed the car after the blower so I can't back up any of the Big HP#'s from other Vortech/Toda equipt cars.
Old Jan 23, 2004 | 06:35 PM
Kwando's Avatar
what is the easiest way of removing that audio panel?
